Lotus "godkänner" Michelin PSS till Evora S (och annat däcksnack)
Följande info från Lotus (ligger också i min tråd under Våra Bilar) kan vara bra att känna till då Pirelli PZero Corsa LS kan bli svåra att få tag i.
Further to you recent enquiry, I have spoken to our Ride and Handling Engineers and as a result I am pleased to be able to report that we have conducted a series of tyre assessments that were completed using an Evora S at the Michelin proving ground in France and our own test track, fitted with 235/35/19 and 275/30/20 Michelin Pilot Super Sport tyres.
These tests used the standard Evora pressures of Front 2.4 bar Rear 2.6 bar. The tyres performed well and were considered an acceptable alternative to the Pirelli Corsa LS.
These tyres were also originally installed on the Evora GTE. (with 380ps engine) and during our tests, the overall tyre performance was very good, with predictable and linear grip levels in both wet and dry.
Therefore based on this information we feel that the Michelin Pilot Super Sport (non-branded) 235/35/19 91Y XL and 275/30/20 97Y XL are an acceptable alternative to the Pirelli Corsa LS tyre used on Evora S vehicles, with no modifications or alterations to existing suspension geometry settings being required.
I hope this helps.
Yours sincerely,
Neil Turner – Customer Services & Warranty Manager
LOTUS CARS LIMITED, Hethel, Norwich, Norfolk, NR14 8EZ, England
Re: Lotus "godkänner" Michelin PSS till Evora S
Bra support från fabriken, måste jag säga.
Verkligen! Det är litegrann det fina med en relativt liten aktör som Lotus, att man har direktkontakt.
Underbart! :steer:
Re: Lotus Evora S SR -13
Lika nöjd som jag är med Cup 2 däcken på bana är jag med Pilot Super Sport på "gatan". De känns lika greppiga som Corsa men slits inte tillnärmelsevis lika snabbt.
Jag rekommenderar både Cup 2 och PSS till alla Evora-ägare som funderar....
Göran wrote:Nya Pirelli bakdäck beställda hos Däckia. Pirelli har inga i lager, men produktion är planerad för februari.
Däckias pris för två Pirelli P Zero Corsa LS 275/30zr20 inkl. moms och miljöavgift är 9182:- (Lotus Gbg pris 11920:- :shock: )
Rena reapriset om man jämför med andra... http://www.mestmotor.se/automotorsport/ ... raste-dack
Patriks
Post by Patriks »
240 000:- för de billigare däcken till en Veyron... Så en årlig försäkringspremie på minst lika mycket kan tänkas. Soppakostnaden kan nog anses som försumbar i sammanhanget :-D
Patriks
Post by Patriks »
Med risk för att spåra ur, här kommer en länk till ett japanskt däcktest som visar att det är lasbilsdäck som presterar bäst:
https://youtu.be/f62Z8Ev9OXA
 :bigl:
Re: Lotus "godkänner" Michelin PSS till Evora S (och annat däcksnack)
I mitt första inlägg i tråden svarade Lotus Customer Service att de testat Michelin PSS på Evora S och med däcktrycket 2,4/2,6 bar.
Efter att ha läst flera inlägg på FB där man hävdat lägre däcktryck - bl.a sägs manualen till 400 stipulera 2,0/2,2 för PSS - mailade jag Lotus Customer Service igen och fick först följande svar:
Dear Mr Forslund,
Thank you for recent your e-mail.
We have not tested these tyres on an Evora so we cannot make a specific recommendation, however, I have spoken to our head of ride and handling and he recommends trying 2.1 bar front 2.3 bar rear.
Thank you and kind regards,
Jag svarade och påminde om deras tidigare svar och att jag nu var "a bit confused" och fick så ett nytt svar:
Dear Mr Forslund,
Thank you for your e-mail - I share your confusion!
I think the problem is that we have not formally released this information and depending who I speak to, I have received different answers.
We would suggest starting at 2.1 and 2.3 and working up to 2.4 and 2.6 bar to suit your preference.
Neil Turner
Warranty & Customer Services Manager
T: +44 (0)1603 732194 | E: nturner@lotuscars.com
Så nu vet jag och ni andra som kör PSS vad/hur Lotus tänker. Det är väl bara att prova. Jag har kört på 2,4/2,6 och definitivt inte slitit däcken i mitten. Har dessutom haft ett härligt (gat-)grepp. Misstänker att lägre tryck sliter innerkanterna mera vilket är problemet med negativ Camber och transportkörning (som det tyvärr blir en hel del av). Lutar nog åt att fortsätta på 2,4/2,6 men sänka OM jag skulle köra med PSS på bana (har ju mina Cup2 för det annars).
Freddy
Post by Freddy »
Har de inte slutat tillverka Michelin PSS och ersatt dem med Michelin Pilot Sport 4s? Det var så jag uppfattade det hela när jag beställde PS4s till min Evora. De kommer för övrigt monteras till helgen.
Jag antar man borde kunna använda samma däcktryck i PS4s och PSS.
Fredrik Arvidsson
Lotus Evora S SR -14
Jag frågade Michelin om PSS i förra veckan. PSS tillverkas fortfarande men kommer ”så småningom” att helt ersättas av PS 4S. Det är bra för mig som snart behöver två bakdäck. Då kan jag köpa PSS eftersom mina PSS fram inte är slut på långa vägar.
Köpte två nya 20" PSS i onsdags (beställde dem på måndagen). Kostade 6.994:- monterat och klart.
Freddy
Post by Freddy »
Min två 20" PS4s kostar 6800kr monterat å klart, om någon vill jämföra priser. Detta ska vara nästa generation, om man får tro informationen på nätet. Så förhoppningsvis så är de inte sämre i alla fall.
Fredrik Arvidsson
PS 4s är helt säkert ett snäpp bättre (konstigt vore det annars). ”Problemet” är om man bara behöver 2 och inte vill ha olika däck på bilen.
Göran wrote:PS 4s är helt säkert ett snäpp bättre (konstigt vore det annars). ”Problemet” är om man bara behöver 2 och inte vill ha olika däck på bilen.
Inte alltid så, ibland har det varit någon ekonom inblandad i "produktutvecklingen" också...
Jag hade samma situation, har två framdäck som knappt är använda. Då känns det onödigt att byta fyra däck när det fortfarande går att köpa PSS.
